Disables SNMPv3 default-group access on the switch.
default-group | Specifies SNMPv3 default-group. |
Enabled.
This command is used to disable SNMPv3 default-group access.
Disabling SNMPv3 default-group access removes access to default-users and user-created users who are part of the default-group. The user-created authenticated SNMPv3 users (who are part of a user-created group) are able to access the switch.
The default groups are: admin, initial, v1v2c_ro, v1v2c_rw.
The following command disables the default group on the switch:
disable snmp default-group
This command was available in ExtremeXOS 12.2.
It was also included in ExtremeXOS 11.6.4 and ExtremeXOS 12.1.2.
The default-user option was removed in ExtremeXOS 22.1.
